2010-2012 MBP 120.000 - 7200mAh Battery inside MacBook Pro late 2008
Hello guys,
My Macbook pro late 2008 needs a new Battery. I found multiple Options on Amazon but i the 5000mAh are just not enough. Im wondering if:
1. Would a battery from a Macbook pro 2010, 2011, 2012 fit inside it?
2. Would the Connector cable be long enough and have the right pins?
I know that the Original design has a protruding connector that sticks out of the bottom case which fits inside a slit of the battery. But you can remove that one and this connector is connected via a cable to the logic board.
Also i have removed the DVD drive and replaced it with a second SSD. If i remove the first SSD from its designated place, could i fit a Macbook pro 17" 120.000mAh battery inside? The length and width of the Battery should fit inside it if i look at the Specs on amazon.
Im on the road quite a lot and i would need the maximum of Battery life.
Does anyone have any experience? Does anyone have the probability to try it out and give some feedback?
