Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
My MacBook rejects os x 10.7!
i had os x 10.6 on my macbook core 2duo,when i wanted to upgrade it to os x 10.7 it wouldnt boot then so what i did is erasing the hard disk manually,finally i tried to install windows 7 but unfortinatly it didnt accept it.
Add a comment
Chosen Solution
We need to know exactly which machine you have. The early C2D MacBook Pros max out at 10.6.8.
Go here and enter the serial number from the back (in fine print) and let us know which machine you have,http://www.everymac.com/ultimate-mac-loo...
Score 3
Add a comment
Most Helpful Answer
Let's back up here you want to upgrade to OS-X Lion 10.7 correct? Why are you messing around with MS Windows! All you'll do is make more of a mess getting the system up and running.
So do you have a retail version CD of Lion or are you using a USB or FireWire drive? If you are using a USB or FireWire drive it needs to be bootable to install the OS.
Score 3
Add a comment
Add your answer
dac osta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 70
