Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
Touch ID fails, double tap works
Hi everyone!
After I replaced the screen (screen only) on my iPhone 6S, the Touch ID fails - even though the double tap for one-handed mode works.
I already transfered the small conductive plate beneath the connector (like described in Touch ID not working after screen replacement?) and took everything apart and reassemled it plus did a factory reset and disconnected the battery.
I was very gently while transferring the home button to the new screen - there is absolutely no optical damage.
What would be the next, you would try?
Could it be a problem, that I used the phone for testing purposes with another display and home button for some time?
Thanks for your help in advance.
3 Comments
The chances are the home button extension cable may be faulty on the replacement iPhone 6s screen, every screen comes with it assembled together.
by
Well, that's worth a try! I'll check it with the old broken display tonight. Thanks :)
by
Didn't work with another screen. Either the Touch ID IC is broken or ... :-(
by
Add a comment
1 Answer
Chosen Solution
I had a very similar situation with a iPhone 6, no Touch ID after doing a screen replacement. Checked everything and nothing was damaged, tried a another screen had the same results. The next time the customer did a IOS update it started working?!!
Score 1
3 Comments:
Yeah I had an issue like this on iPhone 5s. The customer didnt come back so I assumed the touch ID not working fixed itself.
by
Must have been a lucky constellation, so that apple seems to have changed something with the authentication. I'll wait for an update definitely. :D
by
WHAT THE HECK :o
It just started working out of the nowhere :D
Think I had a problem with my magic wand or so...
by
Add a comment
Add your answer
Sebastian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 18
All Time: 1,982
