Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Display backlight doesn't work
Hi, I have a Powerbook G4 A1107 (the low res 17" model) with a display backlight that doesn't work. I'm figuring it is either the CCFL or the Inverter. Is there any way to tell short of, a) purchasing a $100 inverter board and plugging it in, or b) cracking open the Display to see if the bulb is burnt?
The computer has had no other issues, there was no prior flickering before the backlight died, the cables seem in good condition and have good connections, and the display is visible when a lamp or flashlight is placed behind it.
Score -1
1 Comment
the display is visible with another light source behind. It also works fine with external displays through both the DVI and S Video ports.
by
Add a comment
1 Answer
Chosen Solution
Whiles it's booted up hold a flashlight at an angle to the screen and see if you can see the desktop. Also hook up to an external monitor to test the video chip and let us know.
Score 2
1 Comment:
good answer +
by
Add a comment
Add your answer
gabemasiulis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 898
