A corded, electric, 5 amp spiral saw power tool with a two speed motor by Rotozip. The device comes with a variety of drill bits, sanding and polishing wheels, and a carrying case.
4 Questions View all
Why is my blade attachment not spinning?
My saw didn't have any problems before I changed the blade, but now the attachment won't spin at all. I don't know what I could've done to break it, help!
Add a comment
Chosen Solution
Try taking the blade off and attaching it again. If it still doesn't work you might have a faulty attachment. Also, do you at least hear the motor spinning inside? If not, than it might be a more serious problem and you might need to replace the motor itself. Be sure to check out the troubleshooting page for the RotoZip rebel first. Here's the link
RotoZip Rebel REB01 Type 2 Troubleshooting
Add a comment
You did release the lock I assume after changing the tool bit?
Add a comment
Add your answer
Lauren Russell will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 1,466
