Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Screen Replacement Touch ID Function
I took the phone to a repair for a battery issue.
They told me they'll need to replace the U2-IC.
Didn't solve the issue and was asked to return if issue persists.
I noticed that the portrait orientation and compass stopped working.
The repair person tested a different screen (I'm not sure why).
The repair person put my original screen back and the touch ID is no longer working.
I read that using an unauthorized sensor breaks the functionality. What if the original sensor was returned? Shouldn't it restore the function?
3 Comments:
So the tech tried a different screen with its own home button attached to it but then put my original screen and home button back.
Afterwards I kept getting a message that the phone is unable to setup the Touch ID.
I tried your suggestion of holding down the power button until the apple icon comes on but it still says that it's unable to set up the Touch ID.
When I go to the settings to try and set it up it said failed, go back and try again.
I'm still using my original screen and home button nothing was replaced. The tech just tested another screen with a home button on my phone. Did that destroy its functionality?
by
No switching the home button from then non original to the original home button shouldn't do any harm.
by
I'm going to be very surprised if they did not attempt to try another charging dock.
by
Add a comment
First the phone has to have the original home button or the Touch ID will not work. If the phone still has the original home button then reset the phone by holding down the home button then the power and hold both buttons until the appple icon comes on. I had a customer iPhone 6 that the Touch ID didn't work until they updated the phone to the newest software??? Apple is the only one that can reprogram a home button.
Add a comment
If is different new screen then the touch ID will not work but if is yours maybe is just not good connected on the logique board but take back at shop because is not point if was sreen work then after replacement stop it
Add a comment
Add your answer
kevinolega will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
