Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
Wifi and GPS not working after water damage
Hello,
My OnePlus got dropped in water. I had to change the battery and then it seemed to work fine. However GPS isn't getting a fix and the WiFi doesnt connect unless I'm close to the router. Is there any way to fix this?
Thanks !
Score 1
5 Comments
Hi, can you check whether bluetooth working or not ?
by
Bluetooth is working fine.
by
my phone fell in to water i removed the back and dried but my wifi and bluetooth does not work
by
me too is there anything could fix?
by
yeah same happend to me nothing seems to be working sadly
by
Add a comment
1 Answer
Chosen Solution
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First you need to remove the battery as soon as possible from the phone.
Then you need to dis-assemble the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again
Score 2
2 Comments:
Hello,
Thanks for the comment. I wasn't clear earlier so here goes - I replaced the battery and the phone works quite well - except for the GPS fix and WiFi. I have no problem connecting to the work WiFi but phone doesn't connect to home network unless it's very close to the router.
by
Hi, The WiFi antenna connection may have been damaged either by the fall or by the water (corrosion). Either way it has to be opened. Hopefully it seems that it may be not too badly affected, but it won't fix itself.
by
Add a comment
Add your answer
Durga Sury will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 16
All Time: 16,477
