MacBook Pro models with a 15" display
8251 Questions View all
do you need to apply thermal grease to cpu chips?
Do you need to apply new thermo greese to cpu chips and heat sink rails when replacing logic board? i replaced logic board and everthing works great but just worried i should have applied new thermal greese to cpu chips. thanks
Update
ok no worries thanks for yout help . will def go and do it now.. many thanks
Score 4
1 Comment
No Prob, try Artic Silver 5.
by
Add a comment
Chosen Solution
Here is our Generic Thermal Paste Guide, which should help you properly apply thermal paste. Doing it right is very important to avoid overheating issue later in your computer's life cycle.
Score 6
1 Comment:
+ good
by
Add a comment
Yes, you should have applied thermal paste to the CPU. I always recommend that Posters replace the original Thermal Paste that is on the CPU being that Apple uses cheap thermal paste, and it is usually applied very poorly.
Score 3
2 Comments:
+ good
by
+ I use Artic Silver also.
by
Add a comment
many thanks, applied artic sliver as deminstrated in thermal paste guide. works so well sceems to run heaps cooler 2. thanks again
Add a comment
Add your answer
Kurt Russell will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,337
