How many fans are there? Why does battery get over heated?
Coconut Battery gives me a warning that my battery temperature is high (I set it at 35C). What is the safe range of temperatures for this mac?
Is it still under warranty?
There's one fan: MacBook Pro 13" Retina Display Early 2015 Fan Replacement
35c is normal, you can have places hotter tha 35c.
You can set the alarm above 50c
Thanks. Where would we find the reference to the safe temperature(s)? Is the 50C you quoted coming from Apple?
I would start off using a different tool here. Get this: TG Pro for less than $20 US its worth it.
Your battery temp should only be running high when its under charge or have a heavy process running. Using TG Pro you'll get a better view on whats happening in your system. I would also be watching Activity Monitor in your Utilities folder to see what processes are running on your system do you have a rogue app running up the processes?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
1 Comment
Thanks for confirming it. Yes it is still until Nov 2016.
by ALI GHAZZAWI
