Only charging when switched off
Hi
My iphone is only charging when it's switched of... I think it's a hardware problem because i deleted everything on the Iphone and recovered. Sometimes its charging while its on, but most of the time its only charging whend it's switched of... So i can't sync with itunes.
Can you help me? Which part of the Iphone could be broken?
4 Comments
it my just be that your charging port is a bit dirty ... turn off the phone and try to pick out any lint or dirt, try not to use any thing metal.
by Reboot Gozo
Thanks for your reply
I tried, but still have the problem.
When the charging port is dirty, why would then the phone charge when its turned off and not charge when its on?
by Luca Stalder
this can happen as certain pins are not making contact ... remember this is a 30 pin connector so it is quite possible, i like to use a toothbrush to try and get any gunk out
by Reboot Gozo
alternatively ... you might want to change the charging port itself
by Reboot Gozo
