Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6s home button reverse compatible with iPhone 6?
Sorry if this is a dumb question, but I'm looking to customize my iPhone 6 and seems like they don't sell custom colored rose gold home buttons for the 6 to match with custom housings.
Was wondering if anyone here knew if these are reverse compatible? I remember the 4S home button worked with the 4, and the 3GS home button worked with the 3G.
Let me know.
Thanks.
Add a comment
Most Helpful Answer
4s home button does not work on 4.
Replacing the home button kills Touch ID, don't do it.
Score 1
3 Comments:
Nah, it actually works, even though the press nubs/adhesive are on opposite sides, when you install them it still works the same.
by
From what I remember, the flex cable contact pads are reversed on 4 and 4s.
by
They are, but the button still clicks and works when installed with either flex button.
obvious not recommended you interchange them, but I found out when I got desperate during a repair once and it worked perfectly
by
Add a comment
Dam doesn't work dude...my iPhone 6 home button flex cable broke and I have a non working iPhone 6s phone and as soon as I connected the 6s home button to my iPhone 6 it completely $@$* off my phone like it just got killed off and as soon as I unplugged the home button my phone restarted and the apple logo appeared...tried again 3 more times and got the same result...guess I'm gonna have to order a new home button through Amazon hope this helps
Score 1
Add a comment
Problem is that you'll lose your Touch ID function. We replace home buttons for custom ones. We order customised buttons even in non standard colors like green or red. There are also stickers available on market which will change look of your home without lose of Touch ID function.
This is a photo of customised iPhone 5.
Add a comment
Add your answer
Phillip will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 5,968
