Repair information on products used in health and personal care. Fixes tend to be simple and require only common tools.
385 Questions View all
Damaged Hair Folicals How to Fix
I will admit I was bad. But now I totally want everything to be clean. No! toxins whatsoever. A new me a new life! Can anyone out there please tell me is there something that will clean out my hair follicles permanently? Have search the world over for a straight will do answer. thanks
Score 1
Add a comment
Most Helpful Answer
The HairConfirm Laboratory tests the molecules embedded in the hair shaft. Therefore no external or topical source or agent can alter the test results. None of the so-called detoxifying shampoos or products can alter a forensic hair test performed in a laboratory, and therefore the hair drug analysis test is basically cheat proof.
Blood nourishes the hair as it grows. If drugs are in the blood, they will reach the hair along with the blood and be embedded in the hair shaft. It takes about a week after drug use for the drug affected hair to grow above the scalp.
Here's where to obtain testing kits: http://www.homehealthtesting.com/hair-c-...
Consider the Sinead O'Conner look. Tell everyone you had chemotherapy and your hair fell out. Remember that all the hair on your body can be tested not just your head. Your hair will come out clean as soon as the drugs are out of your system. So after ten days the new hair growth above the scalp will be clean and drug free. Here's a link to information on hair growth: http://www.hairfinder.com/hairquestions/...
Score 9
4 Comments:
That was immensely informative, not only in answering the question, but in explaining why on earth someone would ask such a question...thanks!
by
Did you pass the test?
by
Add a comment
In my opinion, periodic deep cleansing will remove the dirt, oil and any residue from hair follicles and this might definitely help you to revitalize your hair. Firstly, wash your hair with warm water, then apply the toxin washing shampoo or apple cider vinegar to your hair that purify hair follicles and provide luster to your hair. However, if you wish to learn more about how to clean your hair follicles permanently, then you can go through some good professional tips at Hairsurgeries.com that will surely guide you in the right direction.
1 Comment:
Sometimes you have to read between the lines ;-} Clearly he was looking for a different kind of answer for a very different need.
by
Add a comment
Add your answer
kathy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 748
