Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
709 Questions View all
Black Screen/ Pantalla negra iMac 27 mid 2011
Hi all,
I have an old Imac 27 mid 2011 top with i7 quad core 3.4 and Ati 6970, recently the screen of the mac does not work properly.
When I start the computer it s black but the Imac works perfectly(I have another screen plug in), but if I wait for a 2 minutes and the imac enter in Slept mode when I turn it on the screen works perfectly during hours, so I think is something like the mac must be warm to work properly.
Does anyone knows how could I repair it?
Thank you very much
Hola a todos,
Tengo un viejo Imac 27 mid 2011 tope de gama con i7 quad core 3.4 and Ati 6970, el caso es que la pantalla del IMac no funciona adecuadamente ultimamente.
Cuando lo enciendo aparece en negro pero el imac funciona perfectamente (tengo otra pantalla conectada y funciana perfectamente), pero si espero un par de minutos y entra en reposo cuando lo reactivo funciona perfectamente, por lo que creo que debe ser algo relacionado con la temperatura.
Alguien sabe como podria solucionarlo?=
Muchas gracias de antemano.
Add a comment
1 Answer
Chosen Solution
Apple may possibly still be covering it under this program but it's iffy:
iMac (27-inch): AMD Radeon 6970M Video Card Replacement Program
https://support.apple.com/en-us/HT203787
If not, do a hot air reflow of the GPU chip.
http://www.ebay.com/itm/2in1-898D-Solder...
Score 2
7 Comments:
@mayer nice answer. You got this message?
by
@oldturkey03 - Yes i did, looks like the @ has to be used to get notifications
I'm repairing lots of previously unrepairable machine with this hot air gun. Especially GPU issues on iMacs. Will start on MacBook Pros next week. I'm having about an 80% success rate. Got eight 2007-2011 machines running in the last two weeks that it had been to expensive to replace the GPUs. It sure beats the cost of a rework station. I watched a few of @jessabethany videos to lean how to do it. Thank you Jessa. Now I have a lot of inexpensive machines for the kids for fall. I have 10 or 12 white iMacs I have not gotten to yet. Will try to get those running for under privileged kids. I have several middle school teachers that can get them into the right hands. Next I'll go for the stacks of MacBook Pros with the 8600 nVidia GPUs.
I'm going to be a busy boy, glad I didn't throw them away now.
by
@mayer yes you need the @ to get notified. Great job on the reflows. One suggestion I have is that you get yourself a good thermometer and proper thermocoupler. Makes the job a lot easier and precise.
by
@oldturkey03 - do you have suggestions for exact models. But using a old $350 Fluke 561 now costs $180: https://www.google.com/?client=safari#q=...
by
Thank you very much, apparently I am going to get it restored!
by
Show 2 more comments
Add a comment
Add your answer
MIguela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,214
