Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Questions View all
MacBook Pro 15" 2011 not charging after battery replaced
Hi everyone
I've bought MacBook Pro late 2011 on Gumtree and not charging
Things what I know:
- obvious things I've done ie. SMC and PRAM reset.
- got 2 front corners bit bent (nothing cracked)
- genuine Apple charger is green light only and when disconnected MacBook switching itself off (even when battery is connected to motherboard)
- new replaced PowerHut brand battery is detected and showing 100%
- new replaced charging port
- MacBook is going to "Sleep" randomly... when battery is connected to motherboard - when press space key it's waking up.
- no visible evidence of liquid damage
- when battery is connected to motherboard and press 'battery button' green lights flash randomly - which means - sometimes all flash and dim like as fully working - other time just one light appear - other time all flash 3 times
- when battery is disconnected from motherboard everything works as it should (apart no obvious hold on charge)
It looks like battery is doing something wrong - but what? It is new and connector looks ok.
Thank You everyone in advance for help
2 Comments
Have you had any screen anomalies? Booting half way through and locking up?
by
No problems like that at all when battery is disconnected - but when battery is connected - yes - they are such a anomalies as You said
by
Add a comment
1 Answer
Chosen Solution
This issue can cause many anomalies, take it into an ASP and have this test run: https://www.apple.com/support/macbookpro...
Score 1
Add a comment
Add your answer
Bart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 966
