Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5S bricked after battery replacement
I went to replace a battery on an iPhone 5S, it obviously should have been a simple replacement but i went to reassemble the phone and it was dead. I have replaced every component to find the issue, the lock button flex, charging cables, screen, different batteries... no avail. I believe it is a logic board issue but I have no idea which part or how to fix it.
Is there something that a faulty battery or battery replacement could do to brick a 5S?
Any help would be greatly appreciated.
Score 2
Add a comment
Try the original battery again.
6 Comments:
I tried the original battery and a battery from another 5S - neither did anything. The phone remained non-responsive to anything - not recognised when plugged into my Macbook either
by
Look closely at the logic board for missing components, had an iPhone 5c a while ago that was missing a tiny resistor and wouldn't show anything on the screen.
by
If I look carefully enough, should it be fairly obvious if there is a part missing? Will I need to take off some of those component shields?
by
i just had the same problem. replaced battery and device bricked. went back to original and can't keep it work again. when i try to turn it on, screen is black, but iTunes recognize it (it asking to unlock the device password, but i can't do it)
by
Yeah, see unfortunately the iPhone isn't even recognised when plugged in
by
Show 1 more comment
Add a comment
Check the LCD connections. I usually don't remove the screen when doing a replacement.
Add a comment
It's not unfathomable that a third party battery could damage a motherboard.
Why not try removing the board and placing in another 5s that you know works? It's the quickest way to eliminate other possibilities? Good luck
2 Comments:
I've done this, tried a new iPhone 5S housing which had components in. I think it must be a logic board issue, are there places that fix things like this?
by
No good news unfortunately... There are people / companies out there that will repair iPhone motherboards, but as you can't pinpoint the fault it could be an expensive experiment. Personally I'd probably sell the phone for spares and look at getting another one :(
by
Add a comment
Hi, I had a similar problem with an A1533 where the battery completely died. Think it was caused by overheating as the front panel w/LCD was detached from its frame!! I jump started the battery using hooked pins and an external low current charger from an old defunct phone pack but had to take it out of the frame to get to them however this worked fine and phone starts/runs with battery at about 20%
The 5S and 5C batteries are very similar but not identical, even if it fits in the available space its connector is wrong.
You might have damaged it in the process so worth checking under a magnifier for bent or missing pins, or a cracked connector housing.
Add a comment
Add your answer
Max Shepley will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,009
