Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
"This accessory is not optimized for this iPhone" Error warning.
I am getting, at somewhat random intervals an error message (see above) it continues with "you may experience interference (etc etc)"
The warning appears even when nothing is connected to the iPhone and if the iPod function is active it stops the music. It also appears to reduce the battery run out time. I have already installed a new battery (1600mah) but no change.
Any ideas what this could be?
Colin P.
Score -1
Add a comment
Chosen Solution
Try cleaning the dock connector. There might be something shorting out one of the pins, and causing this error. A toothbrush is good for this.
Score 8
3 Comments:
The trouble was in the dock connector, cleaning with toothbrush and air pressure did not cure it. I have now replaced the dock connector and everything seems ok. Thanks for the help
by
+ If this solved your problem, you should accept or at least up-vote Chris' answer.
by
GOT IT FIXED! After reading all the stuff about this error, I got a can of compressed air and blew out the connector port. IT WORKED! Immediately the error went away. EAST FIX!
by
Add a comment
Hi,
this message should only appear if a non Apple accessory is connected. Take a look at your dock connector. Maybe something in there is bend and causes a short or something sticks in there causing a short.
Score 2
2 Comments:
Thanks for that. I found the same info on Apple iPhone forums and am working on it.
by
Waited 1 more day to see what happens! It really is ok now. Inspecting the old dock connector under a magnifying glass reveals no damage so I don´t really know if it´s broken or if it was just the operation of replacing it that solved the problem. Whatever, thanks a million for helping to make that annoying window go away.
by
Add a comment
spray alittle polish onto toothbrush and lther, not wet the connector. wipe with a dry cloth and blow hard into it for a minute.
Worked fine for me and no problems for days now.!!!
1 Comment:
just wondering if you could edit your advice... had a bit of difficulty understanding what you mean.... what type of polish? what's an ither?
by
Add a comment
hello guys this issue is coz of dust or moisture content in the doc port or in ear phone port just clean with some brush it should work f0r me it worked
Add a comment
go to this website.
i was on it and there is a lot of really good things to try on there
i personally havent tried any of them yet because i am waiting for my iphone to dry (i dropped it in the toilet) and then i will be trying them all
hope it helps heaps
http://appletoolbox.com/2010/09/this-acc...
1 Comment:
Julz instead of waiting for it to dry and to corrode, try this guide BTW, great link.
by
Add a comment
Very good work, used a small painting brush and it did the job in 5 strokes, i was overjoyed by the work. good job. your a start mate. :)
Add a comment
i have the same msg but when i switch on cel data ist disappear
1 Comment:
and have you tried any of the suggestions on this page??? what happened?
by
Add a comment
Add your answer
Colin Prutton will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 31,294
