Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Forward facing camera not working
I had my screen replaced and then my forward facing camera didn't want to work so they replaced it. Still doesn't work. Do I need to restore? Also will restoring clear everything off my phone? Kind of a novice when it comes to tech stuff.
Thanks
Add a comment
Chosen Solution
Well first make sure to backup the phone. So you can restore it after wiping. Either iCloud or iTunes will work. You should double check your connections first, to rule that out
iPhone 6 Front-Facing Camera and Sensor Cable Replacement
Score 2
2 Comments:
So back up, then restore from back up? Or?
by
Yes, back up. Then restore to the backup
by
Add a comment
Like iMedic said make sure you back up everything to either iCloud or iTunes, then once you restore the phone it'll ask how you'd like to set up your iPhone, then you'll just select back up from (iTunes or iCloud)
Add a comment
Add your answer
Tess will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 186
