2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
Is it possible to replace the trackpad?
My trackpad isn't working at all - I've fiddled with all the settings etc, but no joy.
I'm wondering can I at least take the batteries out (like in the earlier models with the iOpener) to check the zif connector, and hopefully, if necessary, to replace the trackpad...
2 Comments
Yes, I can fix it without destroying battery. But first tell us what happened.
by
My trackpad started acting up, the "click" started to not work - mainly on the right side; my predominant side. The left side still can "click." The right side still can initiate a click operation but with more force needed and there is no click. Is this a sign of impending failure of the trackpad?
Thanks in advance...
by
Add a comment
1 Answer
Most Helpful Answer
Yes you can change the trackpad but you have to get the battery's out and that is no fun task, (or to put them back) the best way is to get something to remove the glue under the battery's, heat won't do anything to the glue as the battery's are to thick... You may find this video useful;
https://youtu.be/pLhHSIej9fs
Score 1
1 Comment:
Thanks very much Ethreal1.. that's just the answer I need, just need to get myself my tools now and get to it!
by
Add a comment
Add your answer
Brian McCrum will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 124
