Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4325 Questions View all
Very weak Wifi, but excellent Wifi when open the front panel
iphone6 can only connect to the 5G WIFI in the same room. But when I open the front panel the iphone6 works well.
And there is a crack at the bottom near 3.5mm jack.
Update (05/24/2016)
no wifi
excellent wifi when open front panel
crack near 3.5mm jack
Update (05/24/2016)
leave a seam at the top then Wifi works well but still weaker than open the front panel completely
Comments:
Have you tried the phone around other wifi networks other than your own?
by
I have tried the other networks. same as my own.
by
Add a comment
Chosen Solution
If closing the phone gives worse WIFI than when it's open, then you may have left one of the antenna cables disconnected when you disassembled the phone perhaps..? Have you tried testing your WIFI when not touching the phone at all? (Sitting it on a table, etc )
Score 1
Comments:
Just some extra information. You have TWO antenna cables. One at the bottom of the logic board, near the main speaker. The other is on the underside of the logic board at the top left. The one that handles your Wifi I believe is at the top.
by
Add a comment
iPhone 6 Rear Case Replacement
Check everything from step 27-31, then the double-L shaped RF bridge cable on the back of the logic board.
Score 1
Add a comment
How did you solve the problem?
My iphone has exactly the same problem. The Wifi gets worse when I push the left upper corner of the screen.
I also have a damage next to the adudiojack.
Add a comment
Add your answer
Jianfeng Xu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
