Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
New Battery wont charge from flat.
Hey all, i've just replaced a dock connector and battery in an Iphone 5, the battery came with roughly 50% charge. I charged it up to 100% and everything was fine. I let the battery drain, which was less than 12 hrs without use. Which was short. Anyway now the battery is flat, i've plugged it in and it won't charge. I contacted where i purchased the battery from and they replaced it. But again, i charged it up, let it run flat and again it won't charge. Could it be that i'm getting rubbish batteries? Could it be the dock connector, altho it charged both batteries while there was charge in them, would getting an exchange on that, cure it? Or could it be something else?
Thanks
1 Comment
Yeah thanks for the replies, it did have a run in with a cheap charger, so i'm led to believe it the U2 chip, i'm just trying to find a repair place and cost in the Uk, with a little dificulty.
by
Add a comment
Chosen Solution
One symptom of tristar chip (U2 chip) failure is an inability to charge a stone dead battery, as well as rapid battery drain.
Score 1
Add a comment
Were are you getting your batteries from?
It sounds that your supplier could have sent you two defective batteries.
Add a comment
Add your answer
Si will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 146
