digital display is on but no fan
Have lights, digital display is on but no fan
Cause 1
Exhaust Fan Motor
To determine if the fan motor is defective, remove the fan motor from the microwave and try turning the fan blades by hand. If the blades do not turn freely, replace the fan motor. If the fan blades do turn freely, use a multimeter to test the motor for incoming power and for continuity. If the motor has power but won’t run, replace it. If the motor does not have continuity, replace it.
Cause 2
Thermostat
The thermostat monitors the air temperature and turns on the fan when necessary. If the thermostat is defective, it won’t turn on the exhaust fan at all. Use a multimeter to test the thermostat for continuity. If the thermostat does not have continuity, replace it.
Cause 3
Main Control Board
The main control board might be defective. However, this is not usually the case. Before replacing the control board, first check the exhaust fan motor and wiring. If the exhaust fan motor is not getting power, the main control board might be at fault.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
1 Comment
tamarafox what model is your microwave? You do have the tools and know these things can kill you if not repaired properly?
by oldturkey03
