Phone will not turn on
I have tried holding power and the home button does not turn on. I took it into the apple store and they said the phone isnt receiving a charge at all and a replacement is $300.
I tried disconnecting the battery and turning it on while plugged in and nothing.
The phone was just laying on my night stand plugged in and decided not to work the next day.
The phone has never had anything replaced.
Is it the logic board that needs to be replaced?
2 Comments
Charging IC chip could be at fault. Have you tried a iPhone 6 battery that has some charge in it to check if if the phone still turns on? Don't need to replace the logic board just yet.
by Ben
Also be sure to inspect the dock flex as well. If I recall correctly, the Geniuses at Apple use a USB multimeter and if it's reading 0.00 amps, then the dock may be at fault as well. Let us know how it goes!
by Tenyouken
