Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
521 Questions View all
Shuts down automatically as soon as I power off. SMC not resetting.
Hello All,
I have been going nuts the last 24 hrs trying to figure this out. Here's the deal:
- Computer shuts down as soon as I pull the power
- Has a new battery
- Has new Ram
- Running 85W MagSafe Adapter
- Battery indicator lights are all blinking when adapter is connected
- Have tried doing a SMC reset (preffered way and manual using a terminal prompt)
- Have tried resetting the PRAM, I know this is not connected to battery issues but tried anyways
I'm at a loss. Need help diagnosing the issue.
Comments:
What is the color of the MagSafe connector LED?
by
it is solid green
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
How about giving this a try, install this App and post a screen shot on what it shows you in your question: coconutBattery.
Score 2
Comments:
I just added it
by
The screen shot is not showing any charging going on. Did you have the Power adapter plugged in? If you did then you do have a bad charging circuit. Is the MagSafe adapter cable damaged in any way? Often I see bad cords shorting out the SMC logic.
by
I tried another magsafe adapter I had on hand and it was producing the same results. What does it take to change out the charging circuit?
by
The systems logic board will need repair or replacing
by
Do you know a general cost for something like that?
by
Show 1 more comment
Add a comment
Add your answer
Joshua Menken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 82
