Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
How to downgrade iPhone device
I want to ask about my iPhone 4S, current version is IOS9 ,and then how I can downgrade to IOS6 . It is due to when I upgrade IOS 9 my IPhone will become lag so I want to downgrade . Got someone got solution to help me ?
3 Comments:
was it io6 before update , ? you would of needed to save the shsh blobs otherwise its highly unlikely its going to work
by
The only say you can downgrade is if you have saved signed SHSH blobs from before for that iOS version like seller1978 said.
by
I not backup SHSH ? How to fix
by
Add a comment
1 Answer
You need to wait for you current firmware to be jailbreakable and you can use tools to help trick the device into thinking ios6 is signed.
4 Comments:
But I don't want jailbreak
by
You have to first jailbreak the current firmware and then downgrade to ios6 which will erase your jailbreak and you will be left with stock ios6. Here is a link to odysseusOTA the tool used to achieve the downgrade. Keep in mind that you will need to be on a jailbreakable firmware. http://www.redmondpie.com/odysseusota-do...
by
Did you mean jailbreak first and then clean the jailbreak?
by
yes exactly. the jailbreak will be gone at the end.
by
Add a comment
Add your answer
JohnChong will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 305
