The current line of iPod touch comprises seven (7) different generations.
2619 Questions View all
Question Closed
iPod Touch went through washing machine
okay so my mother put it in the washer machine and dryer by accident because it was in my clothes and I didn't know, so when i found it in the dryer i dried it off and plugged it into my iPod dock and it worked it lit up but then i saw like stains on the white part of the behind glass and water under the glass i waited for it to charge then used it a little bit to see that everything was ok with the apps and settings, so i put it in a bag of rice for the night took it out and plugged it back in the dock and it worked but once i took it off the dock when it was charged it turned off so i plugged it back in and it worked when i plugged it in then like the next week it gave me a sign to connect it to iTunes i don't know why and it doesn't work if its not connected to the iPod dock and when connected to dock it only gives me the sign to connect it to iTunes, i don't know whats wrong i just want it to work normally again, help? please and thank you!
Add a comment
1 Answer
Chosen Solution
Obviously some internal parts have corroded and/or shorted out. You should have opened and dried it out completely before trying to use. Follow the guides to the right and open it and see if anything's salvageable.
Score 3
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,814
