Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone is searching for network
My iphone 5 today suddenly started started searching network,
I took out the SIM card , it still kept searching for network instead of saying no sim or no service.
I reset network settings, then all settings, turned phone on off several times, put back sim in, hard reset it etc.
I haven't restored it from itunes that I will do next but I am wondering if any one had simlar problem.
Taking SIM card out should changed it to no sim or no service but it doesn't do that so that is weird.
Another thing is it doesn't give me an option to select carrier manually as that option has disappeared from the settings.
Please help
2 Comments:
Do you still have an IMEI number displayed in the Settings > General > About Phone? (Don't post the IMEI number here as it uniquely identifies your phone)
by
whaaaat the !&&*, I cant find it O_o
by
Add a comment
This can happen if the time/date is set wrong. Try manually setting the time, pop the SIM card in. If that connects to network change the time setting back to Auto.
1 Comment:
The date is correct:/
by
Add a comment
There are too ways to solve it.
Method 1(you already tried):
Try Reseting Network Settings by going into
Settings>General>Reset>Reset Network Settings
Your phone will restart deleting wifi passwords and so on.
Method 2:
If it's a hardware problem then the only solution is to heat the baseband ic (under sim tray) with a hairdryer for approximetely 5 mins
According to iPhone could not be restored unknown error 1
Do not try to Restore phone via itunes cause your phone will be unusable (happened to me)
Post back with the results
3 Comments:
So what will happened if I would heat it? He did not get wet :/
by
well, nothing happend
by
You can find your IMEI on the settings? If you can't then it's hardware problem
by
Add a comment
Add your answer
David Jan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 242
