Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
iPhone 5s touch screen unresponsive
Hello FIXIT'S
This Is the First time i've had a problem like this before, wondering if anyone could give us a hand and enlighten me.
I currently have in front of me an IPhone 5s, it had been dropped. (NOT IN WATER)
So long story short, the phone touch screen is not longer working.
I have changed many screens to the same phone / logic board
I have also swapped the logic board into many other working phones also.
But still no touch response?
The problem is clearly with the logic board,
but what is the reason?
what could the problem be down to?
and what location should i be looking in?
Any ideas guys?
P.S
I've also reset phone holding power and home button for 15 seconds etc etc
Much appreciated,
Kyle
Add a comment
Chosen Solution
I'm thinking its either the digitizer socket or the touch IC. Check to make sure those contacts on the digitizer socket aren't bent or not in their proper place. After that it's most likely the touch IC. However you may not have put the phone into dfu and restored from a backup, that could possibly fix the problem
Score 2
1 Comment:
Thanks for your answer pal,
had tried dfu mode and had restored from backup a few times.
still nothing.
i think you are correct about the touch IC
thanks again.
kyle
by
Add a comment
Hi Kyle,
I think you have to restart your Iphone first and then if that won't work then you can try to hard reset on Iphone. Hope it may work sometimes unused applications are the major cause of such issue. Let me know if that works
Regards,
Danny
1 Comment:
Thanks for your reply danny.
I have tried this method multiple times but still nothing.
It is rather frustrating.
regards
kyle
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 255
