Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4600 Questions View all
The difference between the size of an iPhone 6?
I was wondering the difference in size between an iPhone 6 and iPhone 6 Plus logic board
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
If you review the IFIXIT teardown's between the iPhone 6 & iPhone 6 Plus you'll see they are not shaped quite the same nor have the connections laid out quite the same. Yes, there are very similar! But, close only matters with horseshoes and bombs ;-}
iPhone 6 teardown look at Step 15
iPhone 6 Plus teardown look at Step 20
iPhone 6 Plus Image
Guide
iPhone 6 Plus Teardown
Difficulty:
Moderate
iPhone 6 Image
Guide
iPhone 6 Teardown
Difficulty:
Moderate
Score 2
Add a comment
Good question. Just did a little research, and it being that I don't have a spare 6S logic board to measure. Here's what I grabbed
The forthcoming handset should also be 0.16mm taller and 0.13mm wider than its predecessor, likely to accommodate a new display assembly with integrated Force Touch sensors for sensing deep presses on the screen.
Score 1
Comments:
So even though the size is different the connects may still line up
by
No, the connectors are not the same. I guess I wasn't following, what Tom picked up right away. You can't swap the logic boards from one model iPhone to another. It simply won't work
by
Add a comment
if you want to put iphone 6 logic board into iphone 6 plus or the other way around, just forget it
Score 1
Comments:
Why would I forget it is the size different the processors are the same
by
Why is the processor even relevant?
by
Add a comment
Add your answer
paul washington will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
