Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
The bottom part of touchscreen is not working.
I replaced the display on phone and the bottom part of the display is not working I can't get the that menu where you can turn on/off wifi, flashlight etc. Last screen worked jsut fine, it was cracked but the touch worked everywhere.
Add a comment
Chosen Solution
It's your parts. It's possible they were damaged during the install, or even during transit. However it's more likely that you bought cheap(ish) parts, and they aren't working upon assembly. Try this
iPhone 4S Screen
iPhone 4S Screen Image
Product
iPhone 4S Screen
$34.99
Score 1
Add a comment
You said the old one was cracked and the screen function worked fine, try putting the old one back on and check if half bottom is working or not. If it works then you know you have a defective screen if it does the same then you have to troubleshoot down to board and check connectors for bent or missing pins on board where the LCD ribbon cable connects.
Add a comment
Add your answer
mariozunic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 269
