Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
The window was peeling touch the top right of 1mm support
Hello,
I noticed that the window was peeling touch the top right of 1mm support. Is this normal? Is it not a fault fabication ? because the phone is never dropped or shocked and never took the water either. if you have an answer to this problem thank you .
1 Comment
[image|729739]on this picture can be seen the front detached from the support. The question is why it comes off . I know it will change the whole front here but I want to understand if other people have the same problem.
Thank you
by
Add a comment
1 Answer
Chosen Solution
Don't suppose you got any pictures? Guessing LCD is seperating from the digitizer. This can happen on stock phones. You'll probably just need a new display assembly. Yes you could replace just the glass digitizer. But, it's not as easy as it sounds
iPhone 5s LCD and Digitizer
iPhone 5s Screen Replacement
iPhone 5s LCD and Digitizer Image
Product
$39.99
3 Comments:
The glass would be seperating from the frame, not the digitizer. lcd>digitizer>polarizer>oca>glass>frame
by
yes the glass seperating from the frame. but why? it is a default?
by
Kinda. It happens more with aftermarket display assemblies. But it can also happen with oem ones
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 41
