Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
LCD connector dead or bent?
Good day everyone.
I have been replacing the battery on my phone, nothing difficult or unknown.
When the time came to reassemble, the digitizer flex couldn't get into place, but eventually I slotted it in.
On boot up, before finishing body reassembly, horizontal lines were noticeable and when booted the status bar portion was unresponsive.
Suspecting a loose connection I turned the phone off and tried to resit the flex cables one by one. After that I noticed that horizontal lines went away if I tilted the screen to side of volume buttons. Trying to determine the culprit, I flexed the cables a little, and also unscrewed and screwed back the earpiece and its housing.
Lo and behold, now the screen is black on boot. Backlight still works.
Have I damaged the cables? They look fine visually.
Add a comment
Chosen Solution
Ok, so I tested a different display assembly and it worked fine. I swapped the LCD in the end. Sorry to see the original part go, but it had suffered its fair share from a swollen battery and bent frame.
Unfortunately I don't have the expertise to swap flex cables, as I think the fault is in them.
Add a comment
Most Helpful Answer
Have you tried a force restart?
How to Force Restart an iPhone 5
Score 1
1 Comment:
I did. The phone boots up normally, nothing a reboot could fix, the fault is in the hardware
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 397
