MacBook to iMac harddrive
Is it possible to transfer my hard drive from my MacBook A1342 to an iMac 2006?
Update (10/27/2015)
The actual hard drive, but the hard drive I want to put in runs El Capitan. Will this cause a problem?
2 Comments
Are you trying to move the data or the actual hard drive?
by mayer
As you can see here: iMac 24" 2.16 GHz Core 2 Duo (2006) the highest this series can support is OS-X 10.7 Lion unlike your MacBook which can support El Capitan. Sadly, this also means any applications that need to run on the newer OS's won't work in your iMac as well. You can access the files as the file systems are compatible but you will be limited with apps that can run on Lion.
by Dan
