Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Water damage, but still works
I got a question so I got a iphone 6 that's water damaged but still works but has problems, like the baterry is bad and the phone glitches, like when I press the power button it takes a screen shot instead of locking the phone.
So my question is if I switch my mother board to a different iphone 6 that's maybe i cloud locked or bad esn, will the phone work differently from when it was in the water damaged phone, or will it still have the same problems???
1 Comment
The best way is to get it to a fix store to handle this cauz the water is still inside your phone!
by
Add a comment
Chosen Solution
Hard to say. There are few guarantees, when mixing water with electronics. It does kind like if you were to replace a few things, your phone could be back on track. I would try replacing the battery, and the power button, before swapping to a different device. However that could possibly be easier for you
iPhone 6 Battery Replacement
iPhone 6 Power Button Replacement
Here's a couple grade a parts, from ifixit
iPhone 6 Battery
iPhone 6 Power Button Cable
iPhone 6 Battery Image
Product
iPhone 6 Battery
$29.99
iPhone 6 Power Button Cable Image
Product
$16.99
Guide
Difficulty:
Moderate
30 - 45 minutes
iPhone 6 Power Button Image
Guide
Difficulty:
Difficult
1 - 2 hours
Score 3
2 Comments:
Correct me if im wrong, So ur saying that If I change some parts like the baterry and power button it might start working good, but on there hand swapping motherboards to a different phone is a better solution to fix the problem?
by
I'm not saying swapping your motherboard is a better solution. What I am saying, is that the power button cable is a decent amount of work. Could be a bit too much. So instead of just buying the parts, that are problematic. You could possibly buy a phone, with a bad logic board, for cheap. And it could be less work for you. But not necessarily cheaper
by
Add a comment
Eli mnenko, if you switch your logicboard with one that is iCloud locked or has a bad ESN, than your phone will be either iCloud locked or will have a bad ESN:-) Your logic board is pretty much the phone. You can only use those boards to harvest spare parts. Best to do would be to try to fix your phone. start by removing all the EMI shields and checking the connectors and components for corrosion damage etc.
Score 2
2 Comments:
I get what u ment, but I wasn't thinking on using the i cloud locked or bad esn logic boards, I was going to use my logic board from my water damaged phone and put it in the phone that had the i cloud lock or bad esn and see it if still have the pronlems.
by
The damage you describe is most likely on your board. You'll have to clean it properly and re-evaluate after you do so.
by
Add a comment
if your phone has water damage and the man takes the water out and it doesnt work can you fix it
Add a comment
Add your answer
Eli mnenko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 3,306
