Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Is 3G antenna the same as the 4G antenna
Hi,
My iPhone 5 works perfect on 3G however not in 4G.
All settings are right, also provider settings have been checked.
Is the 3G antenna the same component as the 4G antenna or are they separated?
Thanks.
Add a comment
Chosen Solution
I gotta admit, this stumped me for a second. Yes, they're the same antennae. The reason why you're having this problem, is a settings issue. Which, unfortunately I don't have an answer for at the moment. I'll check now, just didn't want you to get impatient and start prying your phone apart
Here, try these things. If it doesn't work, me or one of the other guys around here will be willing to help
https://support.apple.com/en-us/HT201415
Score 1
Add a comment
Most Helpful Answer
First check the models, American iPhone 5 models do not work on European/Asian 4G networks, also true the other way around, only 3G is possible in these situations.
If that is not the case, you shouldn't be looking at the antenna either. Reception by different technology is based on RF front end bands, they share the same antenna. So if your phone has 3G, it is only possible that the amps responsible for 4G bands has broken, that's a logic board issue.
Score 2
Add a comment
Add your answer
Hugo Smid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 756
