Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Questions View all
Question Closed
Why is my MacBook charger not working?
i took out the logic board to clean out the dust from the fan and underneath the logic board because it was getting unusually hot. After putting back the logic board the computer booted up and it is working fine.
however the macsafe charger port now does not work/charge after the operation, and no light comes up on the charger . i have used multiple different charger units but none will work.
any ideas???
2 Comments
i have tried a diagnostics test and have tried an smc reset, no hardware fault identified and the smc test didnt rectify the problem
by
Try PRAM reset, this may trigger it back, alternatively make sure you plugged it in from underneath the motherboard! Also check your charger / use another.
by
Add a comment
1 Answer
Most Helpful Answer
Make sure your Mag-Safe board is fully plugged in: MacBook Pro 15" Unibody Mid 2012 MagSafe DC-In Board Replacement
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 170
