Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
GPS does not work.
I opened my phone up a few months back to fix a home button issue I was having, and ever since then (it seems, I don't know what else could have done it) that my GPS doesn't work. I also get spotty cell reception at times. I have done everything regarding a possible software fix (literally everything) and it hasn't solved the problem.
Any thoughts on what this could be? I've checked screws and connections, they all seem fine. Does my antenna need to be replaced? Any thoughts on this are appreciated.
Add a comment
Most Helpful Answer
iPhone 6 Logic Board Replacement
Step 30-32
Score 1
3 Comments:
Are you suggesting to replace the antenna in the top right corner?
by
No, check the 2 brackets.
by
check the brackets means?
by
Add a comment
Did you replaced the antenna ? or only checked the brakets ?
Add a comment
Add your answer
S Rose will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,112
