AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Questions View all
Question Closed
AC adapter 60W MaGsave donct charge. NO 6.8V cable OK?
MacBook 2008 MagSave stopped charging.
CAble OK but Adapter wont give required 6,8V, nothing.
Warms a bit but not mutchs.
Needs repair. Is it possible DIY* any common faults
Add a comment
Chosen Solution
Hi Mayer
Thanks alot Of your trouble to answer to my Littellin problem.
Yes I tried to Have a closer look Of The pins and their free movement, ok, cleaned them and also on Mac end. No life on pins. With another charger all works.
Finally I Cut The chord and mesured voltage on The two wires ( shield and inner wire) no voltage.
Seems The Fault Is In The adapter?
Is it worth for DIY Man try to fix?
Opened The cover and had a visible look but no burnings or el. Smell..
Pretty impressive content!
Add a comment
Most Helpful Answer
I take it you have tested the output pins with a multimeter. Here are the repair guides: Apple MagSafe 1 Charger
Make sure the pins (which are retractable) are extending fully. I use a wooden tooth pick to test.
Most of the time the case gets destroyed when opening the things. It just about takes a Mac truck running them over to open and there are few replaceable parts unless the issue is with the cable.
The pin out voltages are only on pins 2 & 4 and are listed on the right side of this page: https://en.wikipedia.org/wiki/MagSafe
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 194
