The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3765 Questions View all
replaced 5s battery now switches off when 100% charged
hi guys i have a 5s which had poor battery charge life so i ordered a battery off ebay (same specs as the original) after replacing the battery my phone will switch off if left on charge after it gets to 100% and will only switch back on if i pull it apart and disconnect and reconnect the battery. battery life still isnt great so im guessing poor aftermarket battery but wanted to no if anyone has had the same issues as i havnt come across it before??
thanks
Comments:
hi guys posted this a while ago,i have since replaced the battery with another aftermarket battery which worked fine and solved the issue for a few months now it has started switching itself off again if left on charge!:(
anyone had similar issues?
by
Add a comment
1 Answer
Chosen Solution
Hi Matt,
Chances are if its from eBay, it's a poor aftermarket battery, I would try get another from a reliable source, that should hopefully cure your issues! :)
Score 2
Add a comment
Add your answer
matt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
