The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Is it possible to test the battery with a multimeter?
Is it possible to test the battery with a multimeter? HOw?
iPhones 1rts gen can show charging symptoms, but sometimes is difficult to identify if the problem is the System connector, CommBoard or battery.
Thank you
Score -1
Add a comment
1 Answer
Chosen Solution
Maybe, to get to the battery, use this guide. Then, you could test the 2 leads, that carry power. I believe that this is the red wire, and black wire. You might be able to do this without removing/unsoldering the battery.
Score 1
Add a comment
Add your answer
Flavio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,663
