Gas sensor gauge reading faulty on 2000-2005 Cadillac DeVille?
do I need the full fuel sender with pump?
Hi, If your fuel sensor is bad you will need a new fuel pump as the sensor is part of the pump assembly. I am including a link to a forum discussion on the matter with a possible solution to the pump reading problem and if you go all the way down a possible easy access to the pump assembly. Good luck Ralph
++ nice link
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 10,084
