Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Where is the temperature sensor on the iPhone 6
We had a iPhone 6 come into the shop today and we had to do a water cleaning on it. After cleaning, the phone turns on and seems functional. The only issue is the extreme temperature warning came on and won't go away. I'd like to replace the sensor but I don't know which part it is or if it's attached to the board. Any suggestions on where it is?
Score 1
2 Comments
did you replace the battery after you cleaned the logic board?
by
Yes, it would not turn on with the original one in it but it powered on with the new one. I also had to change out the screen on it too.
by
Add a comment
Chosen Solution
First try a different battery, there is one in the battery.
Then it gets complicated, there are some NTC probes on the board, usually they won't break but they can be shorted causing false high temp. I don't have the layout so I don't know where for sure.
Score 1
3 Comments:
Thank you! I swapped the battery out with another one I had in stock and it worked immediately. That's the first time I had a battery do that to me
by
I found a schematic, if I shared the link would it help you to identify them? I'm having the exact same problem as OP.
by
Same problem. After contact with the liquid and replacing lcd connector this problem came. Probebly during replacing connector, temp sensor get shorted.
I used different baterys, please help. I found in diagram only ic U1602 but am not sure. Sorry for my ENG.
by
Add a comment
Most Helpful Answer
Check this solution,...
Change capacitor and resistor if damage
Score 3
1 Comment:
my problem was solved
thank you
by
Add a comment
Hi i have tried replace 2 new batteries, the problem is still there. I wonder where the sensor is? Probably the sensor is shorted? PLease advice, thank you.
Add a comment
I'm having same problems. Did you finish a solution to yours?
1 Comment:
Im Having same issue. Did you get your problem solver. If so what did you do
by
Add a comment
Add your answer
Munkeyunk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 29,423
