Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
How to fix error 53
hello
i bought my iphone 6 second hand from some one.
the touch id doesnt word and i used the phone for over 3 Months.
when i go too the amac (apple ) the seller wants too try reset my phone (itunes) when hé do this error 53 comes.
so i can't reset the phone and Now is the iphone dead ( connect too itunes) i can not use it anymore because the seller from apple want's too reset.
i dont have guaranty so i checked self with All tips on the internet
- replace the Shield behind the lcd with cable.
- the original screen and homebutton touch id is on the phone.
- try too reset without screen and unplug the connector ( touchid)
- the connector front my touchid is damaged button nobody can repair this.
i need helpppppp
Score 4
Add a comment
Most Helpful Answer
Only Apple can help, nobody else can fix this.
Score 2
Add a comment
Did you tried this solution https://www.youtube.com/watch?v=RKPLVMVc...
Add a comment
Apple has provide an update to solve error 53. http://leak-rumor-fone.blogspot.com/2016...
Add a comment
Apple has released a fix for iTunes error 53 If you get iTunes logo with error 53 and waited for a fix your in luck doesn't matter if you have original Touch ID home button Go to to iTunes download latest iTunes and restore and update as usual Touch ID function may not work but Apple finally allows you to unbrick your iPhones works with 6 6 plus and 6s and 6s plus
Finally Thankyou Apple
Add a comment
upgrade to the new firmware 9.2.1 through iTunes and you should fix
Add a comment
Add your answer
bas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,179
