Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
What shall I do for this problem?
i just dropped the phone .. and it just turned off ??? it only give a response with the charger ??? but it doesn't charge ?? check the video :/
https://mega.co.nz/#!boMF2QZD!0_KK39WuK6...
Score -1
Add a comment
Hello Friend.
Opens the iPhone, and disconnects the battery, possibly with the fall, he puffed, and this failing.
Disconnect the battery, and try to turn on iPhone, connected to the charger.
I think this will make him turn on, if so, have to change the battery.
here you have to guide
How to replace the battery in your iPhone 5s
to test, you do not need to take off the battery, just disconnect it.
Good job!
Add a comment
Here is how you can start your iPhone without power button:
Attach your iPhone to USB cable.
Using the cord, plug your iPhone into computer or any other charging device
It will take few minutes for your iPhone to get switched on. Once, it happens, you will see screen lights with “slide bar” option
Swipe this option to unlock your iPhone.
above steps worked you will have to replace power button as it damaged due to drop,
2 Comments:
Have u watched the video ??? It doesn't do any thing upon connecting the charger ???
by
you should start to troubleshoot from your power switch. here is the teardown guide
iPhone 5s Teardown
by
Add a comment
Add your answer
memoayman10 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 87
