Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
No contact to computer even if diagnostic led 1,2,3 is on
Hi
When I turn my iMac 24-inch 2007 EMC2134 on I hear the startup chimes but it has a black monitor. When I check the diagnostic leds no. 1,2,3 is on, but no light in no. 4. As far as I understand led no. 4 is about the communication between the monitor and the main board.
If this is the case I would expect that the computer was visible on the network or that I could start up in firewire target mode and get access to my files but none of these options works.
Any suggestions to what is wrong with the computer?
Thanks for your help.
Score -1
1 Comment
Have you tried an external monitor? Or have you tried shining a flashlight into the display to see if you can see a faint image of your desktop?
by
Add a comment
Most Helpful Answer
SOLVED
Did you get a resolution? I have the same machine in with the same issue. No POST tone & 3 LEDs.
Have known good replacement parts from an identical working machine. I'm pretty sure its the video card but wanted to see your results before tearing it down.
Score 2
2 Comments:
No, I have not found a solution. I am not sure what is going on. My own logic says it is something else than the videocard. ( no reset PRAM, no visibility on the network, no firewire target mode...), but maybe my logic is not correct...
I am really interested in what you find out.
by
I found a complete identical working machine on eBay for under $300, shipping included. Pulled the video card and put it in the non-working machine. Booted right up. Now I have a lot of known working parts to use or sell.
by
Add a comment
niels prin, here is what the manual says to check first:"
No Video, Boot Chime Heard
The computer will turn on, the boot chime can be heard and activity from the fan or drive can be heard, but the display has no picture or color.
1. Make sure all software updates have been applied to the computer. Refer to KBase article 303903, Intel-based iMac: Installing available updates , and to Apple Downloads for all available updates for the iMac (Mid 2007) model of computers.
2. Check if the computer is sleeping. Press the space bar to wake the computer from sleep mode. Did the computer wake from sleep?
Yes: Put the computer to sleep from the Apple menu and wake the computer again to test. Check Energy Saver setting to see when the computer has been designated to sleep.
No: Continue to next step.
3. Reset your computer’s PRAM (Parameter RAM):
Shut down the computer.--
Locate the following keys on the keyboard: Command, Option, P, and R. --
Turn on the computer.--
Press and hold the Command-Option-P-R keys simultaneously. You must press this key --combination before the gray screen appears.
Hold the keys down until the computer restarts and you hear the startup sound for the --second time.
Release the keys.--
4. Does the computer display video after successfully resetting the computer’s PRAM?
Yes: Restart the computer from the Apple menu and make sure the computer is now working correctly.
5. Make sure the machine is powered off, and remove the access door and front bezel to access the diagnostic LEDs. Plug in and start up the computer to observe the diagnostic LEDs. At this point in the Power On process, you should hear a boot chime, and LED #1 and #2 are On. Is LED #3 On or Off?
LED # 3 is On: The video card and logic board are communicating properly. Go to the next step.
LED # 3 is Off: The video card and logic board are not communicating. Replace the video card. If the issue persists, replace the main logic board.
6. LED #4 should be On when the video card and LCD display have communicated properly to produce a video image. Is LED #4 On or Off?
LED # 4 is On: The video card and LCD display have communicated to produce video. In this case, there is a problem with the backlights in the panel or the inverter. Verify the inverter cable is fully inserted into the cable connector on the inverter and check that the wires have not been pinched. Replace the inverter cable first and then the LCD panel if the problem persists.
LED # 4 is LED # 4 is Off: The video card and logic board are unable to communicate to generate video. Replace the video card and install the iMac Graphics Firmware Update.. If the issue persists, replace the LCD display.
Resetting the SMC can resolve some computer issues such as not starting up, not displaying video, sleep issues, fan noise issues, and so forth. If your computer still exhibits these types of issues after you’ve restarted the computer, try resetting the SMC.
To reset the SMC on an iMac (24-inch 2007)
1.From the Apple menu, choose Shut Down (or if the computer is not responding, hold the
power button for approximately ten seconds until it powers off).
2. Unplug all cables from the computer, including the power cord.
3. Wait at least 15 seconds. The SMC reset occurs automatically once the iMac has been unplugged from the AC power source for several seconds.
4. Plug the power cord back in, making sure the power button is not being pressed at the time.
5.Reconnect your keyboard and mouse to the computer.5.
6.Press the power button on the back to start up your computer.
Note: The iMac (24-inch) does not have a button on the main logic board for resetting the SMC, which eliminates the need to remove the computer’s cover to reset it (as required for some other models).
Let us know what you find out after all this.
Score 1
2 Comments:
The GPU in this 2007 year model was notoriously faulty. I've had to replace about 6 of them. Prices remain high on it because of the demand for the part because so many failed. Last time I checked the 512 option was only slightly higher than the 256K version.
by
Hi
Thanks for all your suggestions.
I tried it all but nothing has changed. The strange thing is that I can't reset the PRAM. Normally I would hear the startup chimes in a loop as long as I keep the keys down, but there is no second chime. Only the first one when I turn the iMac on. I guess that it means that there is something wrong in the startup process. I have tried to remove either one of the ram blocks but it dosen't change a thing.
Can all these errors be a result of a faulty GPU?
by
Add a comment
Add your answer
niels prins will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 134
