Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Removing the fan blade of the MacBook Pro 2011.
Lately, the fan of my macbook pro started to make noises but only occasionally, especially after tilting it. I then disassemble the fan and clean it, reassemble it but the noise will still pop up.
I figure the problem is near the motor of the fan which I was unable to clean because I have no idea how to pry off the fan blade from the axle. I peel off the sticker behind the fan and it has a golden bolt.
Score -1
Add a comment
Chosen Solution
Fans wear out -- the noise you are hearing is the bearing, and it is not user-serviceable. Fortunately, fans can be purchased at a reasonably low cost, and are pretty quick and easy to replace.
Score 2
Add a comment
Got it in one, Marshall. Here's the replacement fan, and here's the guide for the steps. The product page also has a take-apart video.
MacBook Pro 13" Unibody and MacBook 13" Unibody Fan Image
Product
$29.99
Score 2
Add a comment
Add your answer
Bryan Lean will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 225
