Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
New Screen will not turn on. Broke this part off the board...
This will be the fourth screen for this iPhone 6. All other screen replacements have been successful. After installing this screen it would not turn on. Noticed I broke this part off the board where the screw secures the ribbon cable shield.
4 pictures of damage: http://postimg.org/gallery/1wvjsfx8/
The screen works just fine. I've tested it on two other phones.
Suggestions?
Thanks!
Score 1
1 Comment
Any luck with this. I have same issue.
by
Add a comment
1 Answer
Most Helpful Answer
I love this question and I'm totally stealing it to use as an example for my practical board repair workshop!
The deal here is definitely long screw trace damage, which in the iPhone 6, will take out the backlight. My guess is that your phone DOES power on--i.e. it can be detected in iTunes, and what you are describing is no backlight, not no power.
Even better is that I believe that the missing screw bracket is also a red herring---but I could be wrong about that. My guess is that you will have trace damage under all the screw brackets since we know that you did mix up the screws and I can see screws that are screwed into all the other brackets without the LCD shield---which will make all the screws too long for the brackets and therefore pressing into the board.
I have fixed a few of these---I see that you asked for a quote on my iPad Rehab website so I will answer you there.
For anyone else reading this----get your iPhone 6 screens done at Apple for $109+ tax and avoid these kinds of problems
Update: Great news for you Blake---it was trace damage and I was able to repair it.
Score 1
3 Comments:
If you read the full question it says " new screen will not turn on. Broke this part ..."
by
4th screen replacement!!! Do you use it as a hammer? It is likely that some of the circuit board traces were damaged when the screw post was broken off. Will likely require micro soldering repair. Jessa Bethany is one of the members on this site that does this type of work.
by
AND I JUST FIXED IT----thank you very much, hold your applause. It was trace damage as expected. :)
by
Add a comment
Add your answer
Blake will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 216
