A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Questions View all
Toshiba Satellite L655D-S5164 fan makes a lot of noise. How to replace
My Toshiba Satellite L655D - S5164 fan is making a lot of noise and heat. Does it need to be replaced?
Score 1
Add a comment
Most Helpful Answer
Hi here is a link to an article on removing and replacing the fan in your computer. Video and writeup. Hope it helps.
http://www.laptopinventory.com/LaptopInv...
Score 1
Add a comment
I'm not quite sure, but I recommend getting it checked out, possibly at Best Buy? they have a place where technicians can check it out. One of my HP laptops has been making noise for about a year but since I haven't gotten it checked out yet because I got a new one a while back
Add a comment
sometimes you will not required to replace fan. after air blow blocked by dust temperature getting increases and fan controller release the order to speed up fan's RPM to cool down the system. just clean the heat sink and fan blades. noise will be decreases otherwise you have to change the cooler
Add a comment
I forget my desktop password
1 Comment:
I need help to fix it
by
Add a comment
Add your answer
RodR will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,069
