Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Cannot hear without headphones
Why can't I hear anything without my headphones in? It's like the phone thinks the headphones are in.
Add a comment
1 Answer
Chosen Solution
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
I would suspect that the headphone port is damaged or gunked up, causing the pins that contact the headphone jack to remain depressed. The phones interprets this as a headphone being plugged in. You could take a look in the port with a bright light and a jewellers loupe to see if the is the case. If so, then try to wet a small cotton swab with some IPA and try to clean out the port. In a worst case scenario, a replacement port should solve the problem.
Score 2
Add a comment
Add your answer
Linda Wood will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 232
