Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Volume down button not working.
Hello to all,
I have an iPhone 3G that had sea water damage. When I dismantled the phone, connector 5 and its socket of were heavily corroded but I've already cleaned it. I've managed to make the endless reboot stop by cleaning the terminals.
I have one more problem though, volume down button is not working. I wonder if this is a ribbon cable or motherboard problem. Any suggestions how to troubleshoot this problem? Thanks.
Score 1
1 Comment
+ for the successful repair
by
Add a comment
Chosen Solution
those buttons are simply some kind of metal foils.
you can open them and clean them too.
if there is something black inside - use a needle to scratch the stuff from the metal (don't bent the metal too much!)
UPDATE
since it's a board problem i would check the area around connector 5 (bottom left on the picture)
CLICK for a HUGEer version of the picture
i would also take a closer look at the areas with "power" stuff
good luck
Score 3
3 Comments:
+ Ralph
by
nice work +
by
Add a comment
Yes Markus, I agree. I even filed the tip of my soldering iron just to make it more pointed. I had to rest my arms somewhere to prevent my hands from shaking. I'm also not satisfied with my magnifying glass, I should have bought one that's more powerful.
I've seen one of those USB microscopes. They're only good for inspection. I think it's difficult to use it while soldering. Thanks again for your comments. The volume down key is working again. I hope it stays like that forever. =)
3 Comments:
maybe a good video camera would do the job, mabe i'll try that
by
I use headband loopes like these: http://www.google.com/imgres?imgurl=http...
by
thanks for the link richard. maybe i'll try one of those pieces.
by
Add a comment
Add your answer
Gaijin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,101
