Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
Will the 2010 MBPro Screen fit a 2011 MacBook?
I need to replace the display on my Late-2011 macbook, and both time and money are at a premium. I've found an affordable example which will arrive in good time but it's from the 2010 model MacBook, and mine's the late 2011.
Will this screen fit, and work?
1 Comment
I got around this problem by taking the glass from the 2010 keeping the 2011 assembly painful long process but works .
by
Add a comment
1 Answer
Chosen Solution
LCD, yes.
Full assembly, no.
2008 A1278 model uses an LCD assembly with the sleep magnet on the other side than the 2009/2010/2011.
2009 assembly and 2010 assembly are same thing, but wifi wire is 1 or 2mm shorter on one vs. the other.
2011/2012 assembly use different webcam, different webcam cable. Also these do not have wifi card in the lid, and they use a different wifi antenna which will not fit in the clutch cover.
So LCD, yes. Glass, yes. Entire ASSEMBLY, no.
Score 6
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 3,413
